Hi All.
I have an issue with my Baxi boiler, with it cutting out intermittently. It's serviced annually, and has had 4 thermocouple replacements in the past 3 years - none of which have resolved the problem.
I can get the boiler to light, after a lot of coaxing. At first, the solenoid will ping and stop the burners after a few seconds, then they'll burn for a few seconds longer, and so on, until eventually they will burn for a few minutes, when it will stay alight.
However, if it is just on the pilot light for any more than say 8hrs (usually overnight) then it will cut out - the flow valve will pop the solenoid on startup, and I have to re-light the boiler again.
At the moment I am overcoming this by running the boiler all day on one on/off, and using the other two on/off's to fire it up for 20mins twice during the night.
The flame is also a bit orange now - used to be clean blue. It burns more cleanly once the burners have been on for a while, and the boiler warms up, it also bumps a lot but I know that's scale.
Any thoughts?
Cheers
Any thoughts?
Cheers
