- Joined
- 13 Dec 2005
- Messages
- 11
- Reaction score
- 0
- Country
Problem with the above boiler, in that when it fires up after being off for a while it can sometimes get all the way through the sequence up to lighting the burner (i.e boiler, fan and pilot indicators lit, a pilot flame visible) but then not actually light the burner.
If left for some time it might decide to light.
Tends to be when the boiler hasn't fired up for a while. There is a quiet click in time with the pilot flickering, but can't determine exactly where from.
If it does fire all the way up it can run quite happily for hours, then later after being idle, it conks out...
Is this likely to be a relay issue on the PCB - the manual fault guide seems to suggest it is?
Any help gratefully appreciated.
