Hi, I don't know a lot but I am have a problem with the above boiler, it will not fire up. I think it is the PCB. What leads me to this is:-
the boiler turns on, but no fan operation although the front panel led tells me its working.
The PCB has dark brown overheated make just off off the middle and testing the feed to the fan which I believe should be 325 VDC there is none (I have the outer casing off and the air tight inner casing is also removed
Do you think I am right
Crowds
Crowds
