Hi all,
Please help!
The above mentioned boiler packed up for no apparent reason yesterday. All was running fine in the morning, but when I came home from work, tried to put the hot water on and found it was running and sparking, but the pilot light won't catch.
I called an old mate who's worked on hundreds of boilers over the years, and we had a look. We're not Corgi registered or anything but I trust him enough to let him have a go, as he's worked on boilers for 25 years.
Anyway, we took out the pilot burner injector and gave it a blow through and stuck the hoover on it, but unfortunately no joy. As above, the spark keeps going but the pilot (and therefore burner) won't light.
It was interesting to notice that the door on the combustion chamber was silliconed at the top, does this suggest a bodge in the past?
On the panel, the boiler on, fan on, and pilot on lights are all lit. Not quite accurate but close!
We've come to the conclusion that perhaps we should replace the control valve, as there is gas at the pressure test screw - you can hear it coming out if this is loosened slightly, so this suggests that the gas may not be getting past this point and through the valve. Does that make sense?
Or are we going down the wrong tracks? Could it be the PCB?
Much as I'd like to be able to call out a corgi engineer, I am skint as could be - my mrs lost her job recently and we can barely pay the mortgage, and I'm getting quite heavily in debt, so don't really know what to do.
Can anyone offer any advice please? I'm near Bromley by the way.
Please help!
