hi,
wonder if anyone can help.The problem i have is that my gas boiler switches itself off every 30-60 mins and the overheat light comes on.
Its a baxi solo 3 pfl 70.All was well untill recently when i turned off the water supply to my water tank and drained it.I done this because ive ripped my kitchen out and i wanted to cap the hot and cold water pipes.
I done this and then refilled my water tank and now when i put the heating or hot water on the boiler will run for a while 30-60 mins then overheat and shut down, when i switch of for 10 secs then back on it will once again run for 30-60 mins.
The water pump which is a grundfos ups 18-60 seems to be running fine although a bit noisy and it has been running even though the H/W and C/H are both off.
I know nothing about these things and im happy to get someone in to look at it but maybe its something stupid ive done.
Thanks for any help/advice.
