Baxi Solo 50/4 RS - pilot light not staying on
23 Mar 2009
Cheshire
I've got a Baxi Solo 50/4 RS wall mounted boiler. I noticed the pilot light was out and tried to relight it. It would light but wouldn't stay on. I suspected the thermocouple so replaced it but no change. When I check the manufacturers instructions it suggests that the Boiler Thermostat may need to be reset. It says it's behind the control box - it isn't! Does anyone have any advice to help?
Have you got a sealed system? If not there is no reset o/heat. If thermocouple was fitted correctly and working, i'd suspect pilot blockage/length, interrupter leads, gas valve.
Do you have the little blue wire just where the t/couple joins gas valve . MAke sure connections are fully pushed on and that the connector block is under the t/couple correctly
