baxi solo always on with timer off or stat down.
21 Feb 2006
Leicestershire
:? Any help.I have a baxi solo 2 40pf boiler.When i switch on the electrical suppy to the boiler it fires up even when the timer is off .Turning the thermostat up or down has no effect.
Any ideas? Thanks Pete
Could be stuck microswitch on motorised valve. What (if any) motorised valve(s) do you have?
Do you have a second motorised valve somewhere? Probably same type. Basically you need someone who's competent to carry out basic electrical checks and who can understand a simple circuit diagram. The Danfoss site may have the circuit diagram for your system, or see Honeywell S Plan (assuming you have 2 motorised valves). Also lots of other threads on this in this forum - try searching.
