Hi there I have a problem with my baxi solo2 pf50 not firing up, when the control switch is turned on for hot water or heating the boiler light comes on the fan light comes on and fan runs perfect the pilot on light comes on however the pilot does not light but sparks, burner light does not operate boiler does not fire up.
When i remove the boiler cover and combustion box door (4 clips holding combustion box door on) there is another panel fastened on with 5 screws on top, if i pull this panel away about 1" at the bottom the spark then ignites the pilot light and then the burner ( burner on light on) and boiler works perfect if I close the panel to the burner goes out pilot light goes out but still sparking.
The boiler had new fan fitted 12 months ago, new gas valve fitted 14 months ago, pcb board changed recently.
As I say wont work with covers and combustion box door (electrode sparking) but fires up and works perfect with cover, combustion box door and heat exchanger cover pulled out 1" at bottom.
Any help would be much appreciated.
Ken
Ken
