Looking at a boiler for our 4 bedroom, 1 bathroom + 1 ensuite house. It'll go in the loft, so space isn't a problem.
Been advised to go for a Combi that can deliver around 35 kW of hot water heat output. All the below seem to fit the criteria, and as far as I can see there isn't a lot of difference between them.
The flow rate on the Valliant seems a bit lower than the other brands. And the Viessman seems to deliver as much as the other ones for a lot less money! The Baxi has the best flow rate, is a bit cheaper than the big names and comes with a free filter. The Worcester Bosch has the fancy name, I guess.
Any thoughts/suggestions? Am I missing something?
Best to stay in the same post:
https://www.diynot.com/diy/threads/best-screwfix-boiler-for-4-bedroom-detached-house.566932/page-3
Mod
- VIESSMANN VITODENS 050-W GAS COMBI BOILER (Stainless Steel Heat Exchanger)
- BAXI 836 GAS COMPACT COMBI BOILER (Stainless Steel Heat Exchanger)
- VAILLANT ECOFIT PURE 835 GAS COMBI BOILER (Aluminium Heat Exchanger)
- WORCESTER BOSCH GREENSTAR 8000/35 STYLE GAS COMBI BOILER (Aluminium Silicon Heat Exchanger)
Mod
