That it's in a bathroom is irrelevant. Part P applies to any work whatsoever on fixed electrical cables or fixed electrical equipment located on the consumer’s side of the electricity supply meter which operate at low or extra-low voltage and are—Technically because it's a bathroom changing the type would come under Part P and so to do correctly as DIY you are looking at £100 plus and that does not include the fitting.
I would strongly advise not hacking at a lampholder to force it to take a lamp it's not designed for.
...Want to change to standard pendant fitting......
As you say, it's a real bodge. I'm therefore a little surprised that you and BAS are bringing it to people's attention - particularly given that it doesn't even relate to the OP's question.Somebody has found a way to bodge a BC3 fitting and it is described HERE .
It is a real bodge though and could lead to bad/loose connections with all of the problems that these can cause. I wouldn't recommend it...
I'm notI'm therefore a little surprised that you and BAS are bringing it to people's attention
Even though you 'strongly advised against it', you mentionedI'm notI'm therefore a little surprised that you and BAS are bringing it to people's attention
- which is something the OP probably had not even considered.hacking at a lampholder to force it to take a lamp it's not designed for.
For anyone interested, I recommend this site/article: http://architectures.danlockton.co.uk/2008/07/21/how-to-fit-a-normal-bulb-in-a-bc3-fitting/[/QUOTE]
Err.... that's the link that Eric posted in his reply to you....
http://www.google.co.uk/search?q=ba...a=X&ei=PPcnTqLRL9KBhQe10rD_CQ&ved=0CEcQpwUoAQThe fitting currently in place is a straight batten type. My desire to change it relates to the limitations having such a fitting places on choice of light shades etc.
So have you just got an open shade on the lampholder?When I asked, in a specialist lighting shop, if they had an alternative bulb (I needed a shorter bulb to work with the shade I'd bought, in the fitting as is)
Which Zone is it in?
And when you do you realise that it's a Bad Idea.Dan Lockton does show how to fit a 2-pin bulb to a 3-pin fitting, but I agree with other posts here, that it's not a good idea unless you understand electrics.
In what way?The wiring for the light fitting I have is complicated,
//www.diynot.com/wiki/electrics:lighting
and my question to this forum was based on something I'd read, suggesting that you could attach a standard pendant to the BC3 fitting by simply wiring the pendant rather than removing the batten fixture.
Pendant:
Batten fitting:
It could well be impossible.Evidently, based on the responses folk have made, it isn't that straightforward!
Replace the batten fitting with a bathroom light?I can't afford an electrician so will just have to find an alterative to the shade I bought!
Can we have the full quote, please:Even though you 'strongly advised against it', you mentionedhacking at a lampholder to force it to take a lamp it's not designed for.
Well he might have considered it, after Eric pointed him at a site showing how to do it in the first reply in this topic:- which is something the OP probably had not even considered.
i.e. before I said "I would strongly advise not hacking at a lampholder to force it to take a lamp it's not designed for".All we can do is direct you to this.
If you read the pre-amble I added, I think you'll find that the full quote was effectively all there (albeit not all 'quoted').Can we have the full quote, please:Even though you 'strongly advised against it', you mentionedhacking at a lampholder to force it to take a lamp it's not designed for.
My sincere apologies - I missed that. As you say, my criticism now shifts from you to Eric (and remains with TTC).If you want to criticise anyone for possibly putting the idea into the OP's head, speak to Eric, not me.
