I'm fitting a stone resin tray into a niche in an ensuite bathroom. The manufacturer says that it must be bedded on weak mortar, which is fine, except in the position our tray will be, it is impossible. However, as the tray is over the garage, I can inject PU foam unde it, by drilling holes through the floor and then sliding the tray into place and injecting foam from underneath.
Any of you clever people out there see any reason why I shouldn't do this?
