hi can any one help with this,
i have taken a spur of a wall socket and fed this into a fused switch to reduce current to 3 amp then fed from this to a switch which will control the wall light (on /off) the problem is that i must be wiring the switch wrong as it keeps blowing.
i have earth, live and neutral from the fused switch and have also the same going to the wall light.
i only have options to connect to L1 or Common.
Does any one know what i might need to do
Thanks for you help!
