Evening all,
Just bought a second hand Beko Heat Pump Dryer and have a couple of issues with it:
1) The moisture sense/auto-stop feature does not work - i.e. stops after 5~10min claiming it's finished. (only Timed drying works, and works fine apparently)
2) The inside lamp flashes all the time the door is open (and who knows maybe when closed!)
Regarding 1), I've had the sensor off and cleaned it, PCB out and cleaned it, checked electrical continuity between bars and PCB traces (confirmed) and run some wires out to measure the voltage on the bars while the machine is running (basically nothing - ~50mV DC, a few mV AC). I've not got an isolation meter to-hand but plugged in a small meter says 140kOhm across the bars.
So it seems like a PCB issue I thought.
But then, how about 2) - I guess it is the lamp module that has given up the ghost...I don't really care too much if the lamp flashes, but, is there any chance it could be a signal from the lamp module to the PCB that's missing, and causing the moisture sense/auto-stop feature to be turned off?
It's a bit of a long shot - the machine only runs with a closed door as you'd expect, so if that's fine then moisture sensor should be powered up too...So I'm back to assuming it's the PCB. Anything else to check before shelling out for a new one do you think?
There are no error codes
Thanks in advance!
Thanks in advance!
