Beko fridge freezer making a very loud buzzing
29 Sep 2010
Tyne and Wear
I have a beko fridge freezer that has suddenly (in the last 2 hours) started making a loud humming/buzzing sound. Its usually a quiet hum. Im not sure of the model number but it is only around a year old. Its difficult to access the back of the unit as its fitted into a space but there is room for air to circulate. It has a temperature dial on the inside roof of the fridge which is always on minimum. The noise seems to be coming from the lower right hand side of the unit as you face the front. As its only just started making the noise I havent noticed if the freezer is defrostiong tho everything seems ok at the moment.
move about a few inch incase its vibrating on something [ajoining cabinet for example]
Thanks. I don't know whats happened but i went to bed last night before seeing your reply and it was still making the noise but all day today its been quite so ive not touched it. Im hoping it was just a one-off incident but if it happens again i'll try your suggestion. Thanks again!
