Beko LA87 Fridge seems too cold
25 Oct 2008
Yorkshire
I have checked on the web and found that the operating temperature for a domestic fridge is between 1 and 5 degrees C. At the moment our fridge is about 3 degrees and the thermostat dial is on 1 (the warmest setting). I turned the dial to 3 (the mid setting) and the fridge temperature moves to 0 degrees. The manual suggests moving the setting towards 5 (the coldest setting) in the summer months. I think ice would start forming if I did this.
Is there a fault on the thermostat? Do Beko have any known problems? It is still under warranty but the small print says I will be charged if the engineer turns up and no fault is found.
Thanks Mike
