I am having problems with my BEKO WMA1512 in that it will not run the spin cycle programmes A, B and C (Full Spin, Short Spin and Gentle Spin) on their own. If these programmes are selected, the programmer simply pauses and then clicks round to the Stop position!
On a 'Maintenance Wash' (Programme 2 - no laundry) it seems to do everything except draining the machine prior to the final spin, however, selecting Programme D does pump out and drain the machine. Also Programme 9 (Synthetic 30° Mini Wash) seems generally to run right the way through, although that too occasionally has stopped and not pumped out prior to the finel spin!
I have checked to make sure the drain filter, pump and pipes are clear and unobstructed. The motor brushes have been replaced recently.
Similar problems on the BEKO WMA1512 seem to have been discussed several times on the appliances forum back to 2007, so I am hoping someone may be able to help.
As a matter of interest I have been able to obtain wiring and circuit diagrams, and programmer sequence details from BEKO, but they are mainly in Turkish.
One further point, this machine is the version with a single on/off indicator light beneath the push button.
Best regards
John
Best regards
John
