Beko WME7267W changing waste pipe
3 Dec 2010
Suffolk
Hi all
Ive got the above washing machine, the problem i have is that mice have bitten through the waste pipe causing the water to go over the floor and not to the drain. Ive managed to get a replacement hose, just needed to know how to change them over?
Is it a case of pushing it in and turning the fitting or do i need a tool to change it?
Any help always appreciated
cheers
andy
Just follow the waste pipe to the pump and it will be a jubilee clip or a spring clip on it. Pliers or a screw driver is all you need
thanks rocks
The waste goes into the back of the machine at the top on the left. Looks like it needs to 'turn' to unlock, do i need to take the back off the washing machine to get acess to it?
andy
Yes and poss the lid , just to see where it goes.
so i need to take the back off the washing machine to get it out? Doesnt it just 'push and turn'?
if i need to get the back off then no problems, seems a lot of work involved to 'change it over'. If its whats needed then off it comes
thanks
andy
