I'm considering skimming over my artex ceiling and I'm familiar with most of the potential issues in doing so, but as I am not a plasterer I wanted to check something specific....
I know that some people say pva then skim, and some say thistle bond-it then skim but would there be any issue with doing both as a belt and braces approach..... so pva first and then thistle bond-it, meaning less chance of having missed spots (although at the price of thistle bond-it maybe I should just do two coats of that so I don't waste money by having some left over) ?
Then skim with either multi finish (or perhaps even a half and half mix of thistle bonding + multi-finish as that seems a popular method with apparent benefits).
The main ceiling is 4m x 3m but I plan to try two smaller ceilings in the hallway and on the stair bulkhead first because I haven't skimmed over artex before so if I can't do those to a good standard with zero problems then I won't even attempt the bigger ceiling.
I have skimmed several walls before with not bad results (but only two ceilings, with mixed results).
If I were to overboard instead, I would also need to remove the coving and make good the walls (or refit some coving).
Thanks for any advice.
