Hi
I fitted a bench Radiator a while ago in the hall, its now time for me to put the new flooring down, the problem i have is there is so little room between the Rad and the floor that there is not any room for an isolation valve.
I tried to upload image but not working today...
Does anyone know of a split valve that allows you to remove the rad without having to drain the system down?
All the other rads i have fitted i put an isolation valve prior to the rad valve so there is only about 2" of pipe between them and very little water when removed....
Cheers
Cheers
