Bending coated copper
4 Mar 2013
Bradford
If wanting to bend coated copper is it doable if you peel back the coating on the section you want to put a bend on?
What diameter? Coated copper tends to come ln coils and bends relatively easily.
If using a bending machine, yes, strip back the coating, or just put a bending spring in it with the coating still on. Depends how neat you want it.
some of it will still fit in benders without peeling it back depends on thickness and how much play in the formers
