All, would you good people be so kind as to recommend the best quality / value for money disc for cutting 12mm thick quarry tiles, the disc size would be 180mm diameter with a 22mm bore.
The diamond disc in the machine that I have (Clarke ETC6) came with the machine and although new, is struggling badly to cut these tiles, even given plenty of time to cut, the blade struggles really quite badly even to the point that the machine stops due to the blade not being able to get through the tile.
I realise that my machine is not what a pro would use (I'm not a tiler) but would have thought that it should cut these tiles more easily than it does given the fact that it has a 450Watt motor and a no load speed of 2990 RPM, so I'm thinking that maybe the blade is the problem, what do you guys think, is it the blade or is the machine not up to the job or even a combination of both,
your comments / advice would be much appreciated,
Regards,
Davyboy.
Regards,
Davyboy.
