Best CH/HW System for Hard Water Area
25 Mar 2008
Leicestershire
I live in Leicestershire and the water has a Mg/Ca salts level of circa 100ppm, which is said to be borderline hard.
The heatstore CH/HW system has the advantage that it provides mains pressure HW. However due to water hardness the transfer coil in the heatstore which is at 80 deg C +/- is prone to fur up inside. Since the 'fur' acts as an insulator the heat transfer becomes very inefficient. I flushed the system with the recommended chemicals (acid) three months ago but the HW is starting to run out again.
Are there alternative systems which do not have this problem?
Spacethegas
The unit I have is a Flowmax which was long ago superseded by a 'better' model. I replaced the mixer valve (unit cost £85 or so) two years ago and have not had problems since.
