- Joined
- 11 Jan 2004
- Messages
- 47,171
- Reaction score
- 4,132
- Country
Next time you're there, try switching back on, allowing time for it to settle down and then see if it goes off.
EDIT: Sorry, that should have been "on", not "off"...
I think you were right the first time.EDIT: Sorry, that should have been "on", not "off"...Next time you're there, try switching back on, allowing time for it to settle down and then see if it goes off.![]()
I don't think so. For a start, AIUI, it was already off. Furthermore, if it had been on and one switched it off, it would be off, so there would be no need to 'allow it to settle down to see if it goes off'!I think you were right the first time.EDIT: Sorry, that should have been "on", not "off"...Next time you're there, try switching back on, allowing time for it to settle down and then see if it goes off.![]()
I was under the impression that the limit depended on the type of lampholder. IIRC it 16A for BC and ES, 6A for SBC and SES and unspecified for other types of lampholder.A lighting circuit used to have a limit of 16amp, regardless of cable size. I'm not sure if this is in the current regs TBH.
It's a "feature".To clear up any confusion the MCB supplying the light was switched off overnight. Switched it back on today, light came on then turned off after it's usual time. As John suggested maybe just a glitch.
As I said to Lectrician, I haven't noticed any such 'limits' in the current regs. However, if what you say above is (or was) correct, the people who invented that rule obviously didn't subscribe to the view so often seen expressed here (sometimes even in bold or large font!), that "OPDs are there to protect the cable, not what it's connected to"I was under the impression that the limit depended on the type of lampholder. IIRC it 16A for BC and ES, 6A for SBC and SES and unspecified for other types of lampholder.
