Best Grey jointing compound
10 Aug 2010
Leicester
I'm going to try and lay some grey Indian sandstone slabs next week with my dad and was wondering if anyone could recommend a good jointing compound?
Dad thinks we should use a 4:1 mix but we want the colour grey do people use dye's?
I was going to order some geo-fix mix and just brush it in then use a jointer
I'm torn between geo-fix and easyjoint
My dad would rather do it himself says its a waste of money but if the mixes save me time I don't mind paying extra
It really couldn’t be easier than geo-fix.
Just check it’s suitable for your type of slabs.
If using a jointing compound i would use a 2 part type, Geofix has a bad reputation as well as other 1 part resins.
Sand and cement pointing is the best,but not easy for a novice to do properly,also in areas that you use pressure washers a lot sand and cement will hold a lot better than resin, and 1 part resins are easily stained with algae etc.
