True, but there are now quite a number of LED drivers that achieve a power factor of 0.95.LEDs rarely, if ever, have unity power factor.
Like these.
I presume that you are referring to "LED lamps" or "LED bulbs". I cannot see how a light-emitting diode could have a non-unity power factor.LEDs rarely, if ever, have unity power factor.
Thanks for confirming.Indeed I was referring to LED lamps.
That's really nit-picking, given that they would never be used like that (since they would produce no light!)But LEDs are diodes and as such have capacitance. So I suppose with very low level AC, too low to forward bias them, they could show a low power factor.
True - which means that the nit was being even more picked!Indeed, but in normal operation they would be run on DC.
Fittings: http://www.toolstation.com/shop/Lighting/p76299
Lamps: http://www.toolstation.com/shop/p80549
Avoid the integrated types, as when one fails in a year or three they won't be available any more and you then have a choice of having one odd one or replacing the entire lot.
Same applies to anything which uses non-standard lamp connectors, lamps with unusual lengths, custom LED modules specific to one type of fitting or anything else which is only available from a single manufacturer.
The spec saysAre these suitable for bathrooms? If not what do you recommend?
That depends on whether the manufacturer says they are, not just on the IP rating.Are these suitable for bathrooms?
