Hi all,
Finally finished adding the last radiator to our heating system so now I'm looking towards protecting it all.
We have an ideal logic+ c30 boiler and 11 rads, most of the rads are new as is much of the pipework, what isn't has been well rinsed through at various times when installing the new stuff, below is a picture of the water I've bled from the system today and as you can see it's fairly clean.
Above is a picture of the pipework next to our boiler, I believe there is plenty of room there to fit a magnetic filter so my question is which one to go for and secondly which of the 2 pipes is the return?
The one marked 1 goes to the valve that is opened when topping the pressure up, the one marked 2 goes to the pressure gauge.
And finally how much inhibitor do I need, most of the rads are double panels, I've already got a litre of the below flume stuff that came free with one of the rads I bought,
Is that suitable or should I go for another brand or product? I believe I'll be able to introduce it to the system through the filter once fitted the after running the system for a few days I'll be able to test the strength in the filter and adjust accordingly?
Thanks,
Chris.
Thanks,
Chris.
