Best Method to Remove wallpaper from STUD wall??
23 Apr 2022
Hello
I want to remove the wallpaper from a stud wall and paint it, what is the best approach?
Use a scorer and sponge with hot water or use some lining paper over the existing wallpaper and then paint it ?
Peal the top surface dry. Start at corner and go slow trying to get the biggest bit off in one go.
Run damp sponge over backing twice over 20 mins and should come off easy
Apply gardz to neutralise paste. Spot fill. Paint
Don't...
People stream and damage wall so bad it needs plastering.
They start in middle vs down bottom corner.
The pull little bits quickly vs slow large pieces.
I tend to start pealing dry vs wet.
If that don't work you may need to wet top surface vs dry but most come off dry
Why do you think it needs scoring?
If the paper is not waterproof I find a garden sprayer, misting the whole wall a couple of times, gets it wet enough. Add a tiny bit of WUL to the water.
If the wall is plasterboard, take care not to damage the paper skin.
Best tip I got from a time served decorator was to score and soak with sponge and leave overnight. Or leaver steamer on overnight. In both cases tough old 1930’s wallpaper just peeled off.
Blup
Hello
Is the stud wall plasterboard?
If so, is the plasterboard 'skimmed' with plaster, or is just bare plasterboard?
Blup
Surely if left overnight it will be dry by the morning? Whenever I've used a streamer, it runs out of steam after half an hour or so, so I can't see that working.
The safety cut out is triggered when the water runs out.
Blup
What's the point in leaving it on overnight then? Surely it will cut out after about half an hour and then dry out while you sleep?
What's the point in leaving it on overnight then? Surely it will cut out after about half an hour and then dry out while you sleep?[/QUOT
It had several goes that evening, and was left on, in the morning the water had penetrated and softened the wallpaper, old 1930's stuff, which just peeled off.
Blup
