    Dismiss Notice
Best methods to alarm garden?
Discussion in 'Alarms, CCTV & Telephones' started by perky416, 26 Feb 2020.
  1. perky416
    perky416
    22 Sep 2017
    107
    Thanks Received:
    2
    Country:
    Hi guys.
    Currently using the ERA homeguard alarm which works pretty well. However id like to protect my garden from intruders as well as my home.
    My original idea was to use those cheap chinese duel beam ir laser sensors with the relay output replacing the reed switch on the magnetic door contacts from the ERA alarm, sort of a hack so i can use the laser sensors with my current alarm system.
    I have used these dual beam things at my previous house and they worked great, however at this house there is no way i can avoid placing them in direct sunlight and they will have to be placed on walls with the beam running parallel (instructions say to have it mounted 1m away from a parallel wall), it doesnt look like ill be able to use them.
    I want to protect 3 areas...
    1: garden wall so the alarm trips of someone climbs over.
    2: across the bottom of the garden behind the garage.
    3: across my patio incase somebody approaches my the rear of my house.
    Anybody have any ideas as to what else to use rather than the ir lasers? Or perhaps a way to still use the ir lasers even in sunlight and so close to a wall?
    PIR is out because the dog has free roam when im not at home and the garden wall is low so would pick up the neighbours.
    A tricky one i know.
    Many thanks.
  2. Sponsored Links
  3. secureiam
    secureiam
    20 Jun 2014
    5,344
    Thanks Received:
    667
    Lancashire
    Country:
    thorny bushes./ roses, so when the come over you here the screams.
    You can get beams, pirs the look in certain directions and the mounting of these are the important thing to get right.
    Without seeing the areas its difficult to say.
    The next question comes down to budget and ERA homeguard isnt exactly considered high grade
  4. Handymanjo
    Handymanjo
    2 Feb 2016
    1,861
    Thanks Received:
    363
    Newark
    Country:
    Look at Pyronix enforcer range. Control panel can use external sensors and could be set up for different areas to protect perimeter and internal separately.
    Do not buy cheap Chinese rubbish.
    Buy cheap buy twice !!!!!!!
    • Like Like x 1
  5. perky416
    perky416
    22 Sep 2017
    107
    Thanks Received:
    2
    Country:
    Ive had a thought, its the receiver that cant cant be in direct sunlight the transmitter should be ok, i may be able to work it so that at least the transmitter is in the shade.
    On a side note, budget doesnt doesnt really concern me for the right system (within reason, dont want to be sending thousands lol), i was going to get a risco but id want to install it myseld and the suppliers seemed to only offer it with installation.
    What would be the difference between a decent alarm system and the ERA home guard say?
    It has never failed me, never had any false alarms, triggers if you try to jam it, has a very good range (have a wireless pir at the far end of the garage), sensors are cheap enough to chop and change and alter my system as i see fit, it notifies my phone via the app when triggered, never had a problem.
    Its not really the alarm system its the sensors, chopping out the reed sensor and replacing it with the relay contacts isnt a problem and keeps the sensors wireless. I think its a task of finding the sensors that meet my needs.
  6. sparkymarka
    sparkymarka
    16 Feb 2011
    8,801
    Thanks Received:
    1,340
    Sheffield
    Country:
    Big dog then ?
  7. CJRatch
    CJRatch
    20 Sep 2014
    209
    Thanks Received:
    51
    Staffordshire
    Country:
    A well trained German Shepherd is what you need.
    Edit: Sparky beat me to it.
    All those sensors won't stop an intruder if they really wanted to break into your property.
    A well trained Shepherd however would have them regretting the decision sharpish.
    • Like Like x 1
  8. Sponsored Links
  9. secureiam
    secureiam
    20 Jun 2014
    5,344
    Thanks Received:
    667
    Lancashire
    Country:
    they have been known to dope meat.
    you can have sensors that pick up in the garden, but the best things to have is thorny bushes, looks better than barbed wire and will leave dna behind as it tears the skin.
    As for installing in the shed, if you have mains power in the shed don't see why it couldn't be installed in there, depends on whether its a decent shed or just a a cheap flimsy thing I guess
  10. Gibbies
    Gibbies
    17 Nov 2019
    109
    Thanks Received:
    9
    Country:
    There is no place for racism on this forum please!
    • Thanks Thanks x 1
  11. bernardgreen
    bernardgreen
    3 Nov 2006
    25,549
    Thanks Received:
    2,548
    Bedfordshire
    Country:
    Attaching leads to the sensor PCB might alter the power / sensitivity of the wireless antenna.
  12. secureiam
    secureiam
    20 Jun 2014
    5,344
    Thanks Received:
    667
    Lancashire
    Country:
    Risco do have the Beyond DT Wireless Outdoor Detector with Camera, which means it trips and you get a picture, but you could do the same with CCTV and wire in an external detector and get it to send an image from the CCTV.
    Its not usually recommended to have garden sensors tripping the bell box.
    A video door bell could do the same and you could then talk, once you have verified its a person and tell them to go away.
    Lots of options but the best option depends on your layout specifically.
  13. footprints
    footprints
    21 Sep 2011
    4,466
    Thanks Received:
    957
    Country:
    The Romans used geese brilliant alarm system and eggs too!
  14. bernardgreen
    bernardgreen
    3 Nov 2006
    25,549
    Thanks Received:
    2,548
    Bedfordshire
    Country:
    Not only the Romans, there are are ( at least ) two geese protected sites near here.
    • Like Like x 1
  15. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
