Just had an extension done and was after some advice on the best structure/way forward:
My BT master socket was destroyed by builders – not happy but I will replace this with a new one under the stairs.
So in this location (under stairs) will be the following:
1) New master telephone socket (inc iplate) with two outputs, one for broadband and one for phone
2) Router with 6 wired output and wireless
3) Server hardwired into one of the router outputs so other rooms can access media content
4) 30 x RJ45 cables
most of the RJ45 cables aren't needed yet but I was hoping to hardwire a couple of rooms and use one for a phone as this is necessary for sky. Is this possible with RJ45? How do I wire a Ethernet cable for a phone? Do I follow the same colour guide just ignoring the other colours/cables?
What kit would people buy? Do I need some sort of patch panel or can I just put a phone cable on one end of an RJ45 cable, run this in for sky then just add Ethernet connectors to the rest and plug them into my router, getting a larger one in the future if/when necessary?
Thanks for any help
4) 30 x RJ45 cables
Thanks for any help
