Best paintable cabinets for alcove cabinets
27 Apr 2023
Good afternoon,
I’m based in the UK and hoping to build some cabinets into my alcoves and then build bookshelves on top of them. To make this task easier, I am hoping to use a shop bought set of cabinets that I can assemble and subsequently paint at home.
Unfortunately due to minimum order requirements, a lot of kitchen suppliers won’t supply just 2 900x300 cabinets as it doesn’t reach the spend threshold.
Can anyone recommend a good value cabinet supplier where I might be able to get these? I am looking for units that can be painted to match the wall and I don’t want to have to spend an arm an a leg if possible!
Thanks in advance for your help!
Kind regards,
Matthew
I made the assumption that these standard units weren’t paintable but perhaps I’m making this more complicated than it needs to be?
Do you know if these are paintable?
Thanks for your help
Kind regards,
Matthew
Kitchen cabinets are melamine covered, they can be painted with appropriate products.
I have some (Ikea) Billy bookcases to paint at some point which are also melamine covered, my research eventually had me speaking with Zinsser, they're recommendation is as follows:
1. Wash them with hot soapy water and dry off (ie washing up liquid).
2. Wipe over with isopropyl alcohol.
3. Prime with Zinsser Bullseye 123 primer.
4. Paint with whatever paint you want to use, I'll be going with Dulux Satinwood.
I suspect I will give them a complete run over with the sander beforehand.
If you google painting Ikea furniture you will see more google results.
