Best Plaster for a rustic finish
2 Mar 2008
Hampshire
I've got a 200 year old cottage down in rural France, the external walls being solid granite 1m thick in places.
As I've been doing it up I took the decision to dry line and insulate all of the internal surfaces of the external walls (the temperature regularly drops to -15 in the winter and it's a git to heat up).
I used the French steel rail studding system, glasswool insulation in the gap and polystyrene backed plasterboards. The house is immediately much easier to heat up quickly as a result, plus I use a lot less fuel to keep it warm.
I'm now at the stage where the whole of the ground floor can be plastered. Normally I would just look to skim and polish to a smooth finish but I think it will look a bit too pristine for what was traditionally a farmhouse. The French only seem to do the joints between boards which I'm not keen either.
Does anyone have a recommend for some way of making it look a bit more rustic. I've left some of the huge stones exposed around the window reveals to give it this look and reckon a bumpy surface would look good but I would want to use the best coating material for the job. I thought maybe one-coat, (but I've read a lot of negative stuff here about it) or even a fine render.
Any recommendations gratefully accepted. :)
Use bonding as that already has a coarse texture, you can have a practice of putting it on roughly until you get the appearance you desire. It will look good when painted and also give you a little extra thermal value :wink:Good luck...
No criticism intended Roy :wink: but Bonding may be a bit on the soft side to leave as a finish, would Hardwall be better :?: or even Browning but I've no personal experience using it :oops:
No problem Rich.
I have seen bonding used in "Olde Worldy" looking places to give the effect of a rough textured wall, and with a few coats of paint on it it looks well. At the end of the day when you skim onto bonding it is still a "Soft" wall, as is plasterboard.. ..It would depend on how many kids Sailorf80 has running around and bashing walls :lol:
No problem Rich.
:wink: :lol:
Thanks for the advice fellas. I think I'll try the bonding. I've asked a similar question on a French Property forum and a guy reckons using a lime mortar/soft sand mix which apparently is traditional.
To be honest I'm more interested in the effect, the time and the cost than paying homage to traditional methods.
Taking half a dozen bags of bonding next time I go over sounds a bit less hassle. I never buy anything over there now, as most of the time I get a quid for a Euro :cry:
Oh and my kids are way past the age where they bump off the walls, getting them out of bed and off the couch is more my challenge these days...now when I were a lad.... :lol:
Decopierre in France (all over the place) Lime based breathable and local flickr.com have some sample photos etc and I saw a vid on youtube
