best prep for dirty masonry paint
22 Mar 2010
Berkshire
i've got masonry paint on pebbledash to paint. it's in pretty rough shape, could be worse, but loads of filthy bits and the odd spot of algae. i have a mate i can borrow a pressure washer off of. thought i'd pressure wash it (perhaps with bleach on the algae or algaecide) -- should I add in sugar soap and then go back and rinse? does the paint need to come completely clean or can i get away with just washed well? will it require hand scrubbing? hope not as it's a big house...
also, i've been told i might need to brush it with a stiff brush -- is this only if the surface is powdery? If i'm pressure washing do i need to brush, too? i have a stiff garden broom -- is that good
If you spray the mildew with dilute bleach (a garden spayer will do it) a week beforehand, the mildew will be killed and will clean off easier when dead and dry
No need to use sugar soap outside. Usually a good stiff brushing is all thats needed. Treat the algae with a algae soulution or neat bleech. If the surface is powdery then use a stabilising solution to bind the surface back.
