Best saw for cutting railway sleeper.
30 Jun 2008
Suffolk
I have an old sleeper, approximately 5 1/2" x 10" x 8'-6", which I want to cut down to smaller blocks for use in my lathe. Not sure what it is made of but it is very, very heavy so hoping maybe oak.
My question is, what is the best way to cut it? I'm thinking a chainsaw as my table saw and hand circular saw don't have the depth of cut. I have a decent bow saw but find they tend to run off parallel when doing thick stuff, (think hacksaw wandering LOL).
If a chainsaw is the way do you have any recommendations? Have a budget of around £100
When I cut up railway sleepers for a wall (these were the old creosote type) I marked all the way around then cut to a depth of 75mm with my skill saw, cutting all the way around then finished the rest off with a panel saw.
Andy
If I had a lathe, I'd definitely get a bandsaw. That way, after cutting into smaller blocks, you can then trim them down to an octagonal shape to save time and mess on the lathe. (i.e. you make a 45° sled to hold the material safely to trim off the corners)
Andy
Thanks Andy. It had crossed my mind to do this but my wife suggested getting a chainsaw. As I've never used one I'm a bit wary but it may come in handy if I find some logs in a forest or something. Think I will use your method for now. ;-)
Yes I have a bandsaw and do this before putting in the lathe, in fact I try to get it quite circular rather than hexagonal. Thanks rsgaz.
It's been outside our patio doors for at least 5 years and been pressure washed numerous times over those 5 years.
I know this won't get rid of the creosote or deep oil but think the other 'contaminants' should have been washed off by now I hope. LOL
The only piece of metal I can see is a u shaped staple protruding about 1/4" but I reckon I can get it out or cut away from it.
And therein lies the problem, I can see. There's a good chance you're going clog, knacker and generally ruin a lot of tools.
Also, although there's a good chance they're oak, they could be teak, which is "full" of silica, which also buggers blades up.
(anyway, if you insist, the answer is chainsaw.)
I have used an electric chainsaw on a new sleeper, it's useful for other jobs too like taking down and sectioning small trees.
With practice it gives a straight cut.
Old railway sleepers are very contaminated, cutting them and turning them on a lathe will throw out highly carcinogenic dust
Blup
my wife suggested getting a chainsaw. As I've never used one I'm a bit wary but it may come in handy if I find some logs in a forest.
The last thing you want to do is be running around a forest with a chain saw, the Police would be called in no-time.
:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Andy
Maybe some small bowls or dishes. It's just to try and gain the experience.
I strongly advise you consider another candidate. There's no denying there's good wood in sleepers, but they're more trouble than they're worth IMO.
WP_20180114_002-5.jpg Fair enough if its for that reason but if you smell creosote as it heats I would stop..pity you didn't live closer, I've got plenty of six year old chunks of yew and two year old 26" cherry buts
