Best screwdriver?
31 Mar 2010
Bradford
I want a powererd screwdriver cause my drill is bulky. I do a lot of work on laptops and phones so I want something small that can take the small security bits and the battery last a while. Whats a good tool?
ok guys yes it's funny but i've never stripped a single screw using a geared drill with a bit extension to do it. i leave it on gear 1 and it's fine. i've actually done this many times so... it works and if you have any recommendations of a powered lightweight screwdriver since drills are quite heavy then please post.
anyone who strips a screw using this method used the wrong size bit. they're usually torx, so you probably shouldn't shove your PZ in it ;)
I guess you use this as a nail gun?
Bosch ixo is the best choice for the people. It is very convenient to use so no problem to use it. It can work very fast and accurate so you do not worry about it. I am using since last 2 years and there is no problem yet.
