Best substitute for Honeywell zone valve?
10 Feb 2007
Cumbria
Honeywell is great, but so expensive now. Do you know best substitute?
Ideally fitting the Honeywell valve nuts and same length.
Keep it.
Zone valves are easy to strip down and clean. The head can be serviced with a new synchronization motor or microswitch.
We chuck enough stuff away tbh. These things shouldn't be one of them.
Cheaper Valves aren't always cheaper long term, I suspect the Honeywell would be more likely to outlast anything the competition offers. It's always worth checking the valve itself is free and moves as expected, motors and heads can be changed relatively easily without disturbing the plumbing then.
Myson aren’t bad valves, nor are Drayton/Danfoss.
After striping down my myson 2way valve body, i am happy to say that unless they (bodies) are leaking, they are bombproof and can be cleaned very easily and have no reason to be removed. They are ingeniously simple.
Drayton seemed the most reliable of the main stream manufacturers. The heads are replaceable on all but the earliest models(as are Honeywell) the paddle can be replaced if needed (so can Honeywell with new ball and plate), the motors can be replaced (like Honeywell, but Drayton need the spade connectors). The Draytons do have a fault where the return spring locating post snaps, but this can be rectified with a suitable length and diameter nut and bolt.
I agree with the two years life of the spring return type, it generally fits with my own experience.
If you can and if the actuator is mounted above / over the water valve, so no water can enter the actuator - then I would strongly suggest looking at MOMO actuators for longevity. They involve no springs at all, and it is the powerful springs in the spring return actuators which put extreme wear on the mechanism and cause most of the issues. In addition, in the MOMO type, the motor is only powered to change position, once position is achieved they are off. The spring return type, rely upon keeping the motor powered, but stalled for all but the HW only position - producing unnecessary internal heat.
DRAYTON OR PLUMBCENTRE own brand which is a rebadged valve made by honeywell
