3 Way (mid) valves - best?
19 Aug 2004
Which is the best 3 way valve to go for? The cheapest would seem to be BES with a ORKLI. Next in prices is Horstmann, then Danfoss, then Honeywell. But which is the best? Honeywell seems to have a wire causes the valve to stay in its last state where as Horstmann always returns. But which is best, given that valves can stick.
Opinions?
Sunvic is probably best. It's "motor open, motor close" so the motor doesn't get burnt out fighting a spring. Most of these valves are c rap, so don't expect a life of more than 5 years for the head.
i got no probs with honeywell, but looking @ a screwfix catalogue, the danfoss control pack is pretty good value. and i would go danfoss. cant say ive dealt much with horstmann. but danfoss are ok, you can get directly comparible actuators if you get the ar$e with one particuliar make :rolleyes:
Although Honeywell valve motors do indeed 'fight a spring' all the time they're open, it's not necessarily a bad design. The Synchron motor is DESIGNED SPECIFICALLY to be energised and stalled at the same time. Ordinarily there's no problem. However, IF the ambient temperature around the valve head is not within limits, then the motor coil will fail. But that's not because its a bad motor!
I would argue that the motor open / motor close design is actually more likely to fail - it has to include more circuitry and microswitches to energise the motor according to desired and actual position. Complexity = more things to go wrong.
