Best thing to box in pipes
29 Oct 2014
Lincolnshire
Hi
I hope you can help....
What is the best thing to box in central heating pipes?
I want it to look really tidy and be able to paint over it well.
Many thanks
I suppose the obvious neat quick-fix for pipework has to be Pendock (sold on-line by UK Boxings, etc)which is made from pre-formed plywood with a pre-painted white surface. There are other products on the market like Talon (plastic) and Zylo (similar materials to Pendoc, tighter radii). They all have the advantage of being quick to install, and if well fitted, looking reasonably good. They don't work well on really wonky wal;ls, though, for which the more traditional approach of 2 x 1in softwood framing with 12mm MDF coverinsg is probably the neatest way to go
Thank you for your reply.
A joiner is coming in to do it for us. He suggested ply wood as he already has some off cuts. But I found that a pain to paint last time we had that (took loads of coats and looked quite cheap)
wasn't sure if mdf or ply wood was good with poss condensation from hot pipes?
Personally I'd go for solid timber....a bit more forgiving than MDF fixing wise, and no raw edge that you get with ply. MDF does paint well though.
However, pre finished stuff that JobandKnock suggests is easier but usually more expensive.
Either way, are you happy fixing the boxing to the walls?
Condensation wont be an issue here.
John :)
Use a pilot drill if you intend to use screws, Leanne - prevents splitting of the material.
Good luck with your project!
John :)
If you are that concerned use the green, moisture resistant MDF (MR-MDF) and pre-seal with oil-based primer, but TBH that's probably overkill. There shouldn't be any condensation on the pipes within the boxing because done properly (i.e. with all the entry and exit cut-outs within 1 to 2mm of the pipes) you are creating a closed environment around the pipe where no condensation can possibly form. Main thing about MDF is to make sure that the edges are thouroughly sanded before priming and to use a thinned-down oil-based primer as your first coat
