Best tool for cutting a 100mm wooden post at precise angle.
10 Dec 2010
London
Hi, I have a staircase with a newell attached to its base. The base is 100mm and I need to remove the newell and cut the base in half at a precise 85degree angle. The base is still attached to the staircase so I have to saw at an awkward angle.
I don't trust myself to get the correct angle with a handsaw especially as it is a sidewise cut. What is the best tool for this job? A handheld circular saw? thanks.
t
Handsaw,
pin a few scraps of timber to the post to act as a guide to run the saw against. If the resultant cut needs a little work to tidy it up then use a block plane or sanding block and paper.
Remember if you think you will go wrong with a handsaw an electric circular will only allow you to make the same mistake quicker :roll:
I have that saw in the link it is the dogs dangleys...
I can find any wooden magnets though although they do have a good selection of left handed screwdrives. :roll:
