Best Tool to Tackle an Ackward Hedge
9 Nov 2009
Edinburgh
I've a conifer hedge I want to trim back with extreme prejudice. It's about 4m long and 3m high. I want to trim it right back to the trunks. It's next door's hedge so I'm going back to the boundary and having a fence built so I can reclaim about 1m of driveway.
Now from the way it's positioned, I reckon I can only tackle it working from the right hand side and work to the left. Also with the way conifer branches are, I think it better to work from the bottom upwards. Problem is I don't really know what power tool is the appropriate weapon of choice. I had though of a small chainsaw, but it could be ackward to handle especially at height. Or one of those 3-in-1 chainsaw/hedge trimmer/strimmer things perhaps?
Has anyone got any recommendations based on experience?
No power tools - a bow saw, pruning saw and a small hand axe are all you need and you'll keep all your limbs ;)
nige is right. a good pruning saw like a silky will be almost as fast as a chainsaw, cheaper and much much safer. Be wary and check each branch before cutting or you may leave a massive hole in their side by cutting something.
I was hoping for something with an engine. It's a big, dense hedge and will take a lot of elbow grease and time doing it old school. In my want-it-now mind I was optimistically planning to get the gig done in a morning.
A reciprocating saw with a proper blade works well.
Using a chainsaw in a confined space such as inside a conifer is a very dangerous thing to do if your not experienced with one.
If you must use a petrol tool use a long-reach pole saw. Then there is little risk of kickback injuring you or maiming you. work methodically and remove the branches to keep your work area clear.
you may need a chipper/ shredder if its more than 15m, the volume of waste will be much higher than you expect.
