We are having a bathroom referb, and the plumber will most likely put those standard isolation valves you adjust with a few flat head screwdriver on the hot and cold feeds to the sink.
We will be having mains cold and low pressure hot from our vented tank going to the sink. Coming into a mono block tap with tails (I know this is terrible for low pressure).
My question is, is there an alternative to the standard isolation valve that would allow us to easily dial down the cold feed slightly so it balanced better with the hot feed? I've read about all sorts of different valves some of which are not designed to be halfway open like this, and others which are. Or am I overthinking it!
