We moved into our house six months ago, which originally had pre-pay key meters, we had them switched to credit meters a few days ago, and as part of the installation the engineer did a gas safe check of all our gas appliances.
Our boiler was given an 'At risk' status due to an air vent to the outside having been installed too close to the boiler flue, which is located in a small upstairs bedroom (which is never occupied/slept in). The engineer suggested to us its more a breach of code than an immediate risk, but that we should get the vent blocked up in case because if the boiler became faulty there would be a risk of fumes coming in via the vent. He suggested we should just fill in the space in the wall with expanding foam and this will make it air tight.
Is this really the best way to go about it? We don't have an issue with blocking it up, we don't have any condensation issues and I believe the previous owner installed them all himself because the tenants they had kept drying clothes inside and causing condensation/damp problems and would never open windows.
Would using expanding foam be bit of a bodge job? If so, is there a way to properly seal the vent off myself that a somewhat novice DIY-er could do or is it just best getting a professional in? I'd rather shell out the cash and be safe, but if it is something easily done myself then I'd rather not spend any more money than I have to.
