Looking for thoughts or advice on this one please
I've got an Ariston Eurocombi A23MFFI. Heap of junk basically, and I know it
It's currently got a small multitude of issues, and is getting worse, although it's always passed the safety/ servicing. The current list of issues:
1. The pump sounds like a bag of bolts. Looks to be ~£100 for the part I think.
2. The little screw on the filling loop is dodgy as hell. A previous owner bashed the head up a bit, and it's getting worse. I *think* it can be isolated at both ends from the pipework, so relatively simple fix to pull and replace?
3. Small pressure loss issue. I've always filled to 1.5 bar, letting it get up to ~2.5 bar when working. It's now loosing about 1 bar every 6 weeks. Some of this I suspect is the filling loop, and there's also a minor leak somewhere in the pipework underneath. (I can't find this or see any corrosion inside or out, but the top of my breadbin under the boiler sometimes gets slightly damp)
4. The newest issue, and one that's got me concerned is misfiring. The fan spins up and the pump starts and it lights then drops off. Everything then repeats and it goes on the second or third attempt.
I'd sorely like to replace with a new boiler, but can't really afford the 1.5k needed.
I've got no problem messing with the DHW side, and know a reasonable amount about electronics, although I don't really want to go after PCBs. Not touching the pump on the heating
Any thoughts on the approx cost to fix this thing semi-reasonably?
