Best way to fix vinyl floor to shed base?
13 May 2011
Lancashire
Just wondering if I should use the spray adhesive or use clout nails that you use for roofing felt.
The shed is 12 x 7 and I have a huge roll of 3mm thick vinyl.
The base is made out of 18mm exterior plywood.
Shed houses a heavy motorbike...
Posh shed I know :roll:
Do you really need to stick it down Alan? If you cut it so it goes tight up to the edges of the shed base, I doubt it will move.
agree, I take it there will be cupboards etc in there to hold it down. If you do find it moving then just get a spray adhesive to go around the edges.
I would get a carpet strip to go across the entrance to stop it getting kicked up.
In the end I bought some evostick adhesive spray and this stuff STICKS :)
I'll use clout nails in the future if it comes away.
Thanks for the carpet grip idea, I will definately use that for the entrance!
