Best way to insulated four pipes close together in loft?
8 Sep 2010
South West Wales
Hi
I have a small loft at the end of my house (above utility room). Four pipes run through the loft, down the middle. I recently boarded the loft except for under the four pipes which remains unboarded. What would be the best way to insulate the pipes?
Cheers
Max
11 Oct 2010
Lincolnshire
By "close together" I assume that you mean too close for conventional pipe insulation that comes as foam tubing.
You could use loft insulation wrapped around them. Also, when I put foam pipe lagging on my pipes in the loft, I had to remove some material about 2 inches wide that was wound around them. Perhaps you can still get hold of this.
