We moved into our flat a few months back and have been gradually removing the carpet as we've gone. It's in an ex-Council block and the floors have all been concrete with bitumen tiles but when we exposed the stairs we were pleasantly surprised to find they were a mixture of what looks like pine and plywood.
However, there's carpet gripper all up them. Removing it from the step seems fine as the wood's a normal strip and there are just a few holes left but pulling the strip from the front of each step (which seems to be plywood) has ripped the front.
Here are some images:
The three stairs I exposed and tried to strip (orange dust is the old underlay disintegrating).
Damage done on the bottom step, pretty big split as you can see
Damage done on the front of the next step up:
So, what is the best way of dealing with this? I can't really clamp it down if I was to stick anything to it so can you actually pull off a layer? That sounds risky also.
Also, is there a really good method to remove the gripper after that?
Ideally we want to paint them all white.
Thanks in advance
Thanks in advance
