Hi all,
I've just studded out a frame on the wall (3x2) to hang a piece of MDF onto (with a hole cut out in the middle for a TV bracket). The 12mm MDF will overhang the frame slightly so I can hide LED strip lighting behind.
The piece is mainly square (1200mm width x 1650 mm height) but the top section is straight for 570mm before the ceiling slants down (740mm slant) till it meets the right hand side of the frame which will now be 1290mm (instead of 1650mm).
I have to offer up the MDF so I can work out the scribe but given the weight of the MDF this won't be possible. If it was small I could use card (folded into the curve/incline of the ceiling) but given the length of the slant/curve, this might prove difficult.
I don't own an awful amount of tools (I do have a adjustable bevel) and don't really want to purchase something for this ...but I'm all ears!
Once the scribe is marked I'll use my jigsaw to cut and eventually caulk and paint (it's at the top).
Many thanks.
Many thanks.
