Yes I'm fitting a kitchen and wishing I'd got a professional in! Anyway...
I have a tall appliance unit which sits up against a run of base units and a tall trim panel to sit in between obviously the wall isn't straight, the wall panel is as expected oversize and needs to be cut to the right depth.
Double checking the scribing technique first - if I clamp the panel so that it is square with the unit and has an even overhang of say 5cm all down the front edge would I then set my calipers to 5cm and scribe to the wall?
Second question, once I've marked myself a line whats the best way to cut it? the panel is MDF with a glossy coating, it cuts quite nicely with a jigsaw with the blade set to cut into the panel (no chipping) but although I feel I'm pretty accurate with a jigsaw I tested some of the offcuts I've made against the wall and they are a little wavey - enough so that I will notice. Is there a better/easier way to make the cut?
Thanks in advance.
Thanks in advance.
