ok guys.
Ive been renovating this house for the last 12 months (what a PITA) but anyway Ive just tarted the bathroom up as I've now moved in.
I noticed straight away that the bath drains off really slowly and after a bit of investigating can clearly see what can only be described as 'orrible gunk down the bath waste pipe.
I tried a plunger on it tonight for a good 10 minutes but its not budging! After some plunging I did start to hear water gurgling and for a moment I thought I had cracked it! but no. Once i ran the bath and tested it, it seems as blocked as ever.
The sink seems to be tapped into the same drainage pipe as when I ran the sink I could hear the bath gurgle!!
Anyway, can anyone give me any nuggets of advice on how I can fix this? cheaply if possible (I did think of a rod plunger type method but Im not sure if this would dislodge the blockage further down the pipes!)
Also, I dont 'think' the external soil pipe is back vented if I understand the meaning of this correctly. The soil pipe comes straight out of the bathroom and down into the ground...whereas my neighbours goes up to the roofline and has a nice little vent assembly at the top.
Am I correct in thinking this stops the traps being pulled to drain?
I read about a Hep V O waste valve being used instead but I have no idea what that is!!
All advice gratefully appreciated
