- Joined
- 28 Jun 2018
- Messages
- 3
- Reaction score
- 0
- Country
Hello everyone.
So i have a lazy spa vagas that i recently moved to the bottom of the garden and there is no power outlet. so i have used by camping 4 way plug as an extension cable .
as the family play in this i am stressing out they might get electrocuted as the manual says dont use extension cable. ?
Now i have the lazy spa plugged into this which has a circuit breaker and rcb
https://www.millets.co.uk/equipment...nOzp9S3itCPuzKovsK4aApCKEALw_wcB&gclsrc=aw.ds
then that is plugged into this
https://www.toolstation.com/shop/p47166
then plugged into the mains in the house
is this set up Okay or am i doing it wrong?
- What Electricity Supply Do I Need To Run My Lay-Z-Spa?
Our hot tubs run on a UK standard 13amp/240V electrical supply. You should always use a grounded socket with RCD protection. All of our pumps come with a built in RCD unit as a safety measure. The socket that the hot tub is being plugged in to should be grounded and at least 4 metres away, at a height of at least 1.2m from the ground. We recommend getting a qualified electrician to install a grounded outdoor waterproof socket with RCD protection (this should always be done by a qualified electrician).
- Can I Use An Extension Lead?
No, extension cables cannot be used with Lay-Z-Spas. The Lay-Z-Spa pumps come with a 7 metre cable which is usually sufficient for customers to reach their nearest grounded socket with RCD protection. If the cable is not long enough, we recommend getting a qualified electrician to install a grounded outdoor socket with RCD protection. The socket that the hot tub is being plugged in to should be grounded and at least 4 metres away, at a height of at least 1.2m from the ground.
- What Is An RCD?
All of our spas are fitted with an internal RCD (residual-current device) this is a cut-out device in the event that water comes into contact with the electrical supply to your inflatable hot tub.
- Is The Pump And RCD Waterproof?
Yes, however the pump should not be left sat in deep puddles of water. The PRCD is water proof to IPX5 and therefore should not be submerged.
