Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hello another winter approaching and the unresolved problem of boiler not firing properly during the wee small cold hours, is rearing it's head for the 3rd winter. The boiler fires up for a few mins then cuts off and the flashing red light appears and F26. After switching it off for a few seconds, then switching it back on, it starts and runs quite happily until the next night. Last winter I pinpointed that the problem occured between 1-2 am as I have the boiler running 24/7. As the mornings are a damp I want the heat on for a couple of hours, this morning at 6.45am, the boiler played it's on off routine. Last winter I called the Npower home team out a couple of times, but because I can get the boiler to work, there is nothing that they can do except to say it was cold in the loft, if the fault was either on the inflow or outflow, not sure which, one of those is not covered by their scheme. Now one of their advisers advised that I get an independant third party to look at the fault. My cover with Npower ends on 23rd this monthand I am not sure what to do. HELP
How big is your system? ie how many rads? Sounds like the temperature difference between your flow and return is too high. Get a RGI or BG or Glowworm to properly range rate the boiler. If Npower boys don't know how to do it, get them to pay for a manufaturers visit. Might be worth noting a properly range rated boiler will not only last longer, it will save you money on your gas bill.
BTW why are Npower maintaining a boiler sold exclusively by BG?
